zonkkk
17
In the past couple of weeks I noticed that when getting in the car, sometimes the radio would turn on with the AM band showing, even though I never listen to AM band stations, but only FM or CD.
This morning driving to work, all was OK, listening to an FM station, and then suddenly it just switched to the AM band by itself.
Anyone experienced this before?
are you sure your not catching the mode button with your knee on the switch i do that quite often haha
My car is exactly the same!! Listening to radio 1 on fm when I leave the car... and when I come back to the car is switched over to 909 am!?!?
Think I've worked this out - if you change the band by using the stalk, it is NOT saved for the next time you use the radio.
So if you want the radio to always to turn on to an FM band - then select this FM band by using the "radio" button on the actual radio unit itself.
Tested this around five times today and each time I started the car up it stayed on the FM band.
Hope this helps
