rcd 510 safe pin?
Oct 3, 2012
580
Cambridge
Bought a dab rcd 510 today and just wanted know if I need to wire in a safe pin as the quad lock diagram looks different from the others I have seen, my car is a pre face lift
Oct 3, 2012
580
Cambridge
Tried to wire up the safe pin today, the unit had power but no screen but I think that was dlwn to not having the correct connections so I have ordered the female iso
Now my old unit won't even ****ing work, so annoyed, anyone know what the problem could be?
Ben750
361
Pontefract, West Yorks.
I've noticed your car is pre-fl and I'm considering an RCD510 for my pre-fl Cupra so wondered if you'd mind answering a few questions?
Do all the steering wheel buttons work as they did?
Was there any VCDS coding required?
How difficult was the dab aerial to route and where did you mount it?
Thanks.
Oct 3, 2012
580
Cambridge
Thanks.
Hi, the steering wheel buttons don't work, I guess I need to get them coded or change the iso conections around on the unit
The aerial is really easy, you just run it behind the glove box onto the windscreen.
