Rcd310 safe pin help, my headunit has no power
holmefield
Forever messing with cars
Oct 20, 2013
578
Right any help would be a big help....
I've got a 2008 57 plate seat leon fitted with the standard headunit, ( mines pre-facelift ) I've just purchased a seat rcd310 that was in full working order....
I've swopped over the main plug in the back of my headunit and I've tried using different 10 amp fuses and its not the fuse, but the Rcd310 will not even power on....now I've read that with mine been the pre-facelift model that the ( safe pin, pin 16 will need a direct power feed adding ) does this sound right???
I've had a look on various threads and from what I've read the safe pin thingy seems to be the issue, but I'm no expert on these things so any advise would be a big help
Has anybody done this??????
cheers
holmefield
Oct 20, 2013
578
Yeah think that's right. I know I had to swap some pins over and connect a second live into the head unit. That was on a rcd 510 though
Cool im having a go today so hopefully this safe pin thingy should give it some power then...can you remember which wire you ran your live feed off?
tundrarocks
323
Newcastle Upon Tyne
Racking my brains to be honest. Im sure I just took a wire from the live on the cars harness and plugged it into connector. I'm sure there is an easier way. Just as long as the safe pin gets power it will power up.
Was a while ago that I did mine then swapped it for a kenwood ddx 4925dab. Wish I had stuck with the rcd510. Easier to use and not much difference in sound quality
manji
190
30
Portugal
If it is the same as the RNS310, it requires a permanent 12v feed on Pin 16 which the pre-facelift Leon doesn't have the wiring for.
So you basically need to splice a 12v wire and connect it to the SAFE pin.
J400uk did it using a paperclip, but I bet there are more 'mainstream' ways to do it. :D
J400uk
1,978
London, UK
:lol: Indeed, and someone out there now has a used 08-plate Leon with a radio wired in using a paperclip!
But yes its just a case of splicing the connection from pin 15 to pin 16. I did take some pictures last year but can't find them now.
holmefield
Oct 20, 2013
578
paper clip eh, mine does have a red wire going into pin 16 but theres nothing there with the multi-meter, so to try it my dad and I ran a live of the positive battery terminal and pushed it into pin 16 and it worked hey presto....
So now I know its got power I've put my old headunit back in whilst me and my dad figure out which live terminal we are going to use using pin 15 mite be the simplest idea...
I'm waiting for my new double din fascia to arrive @ the mo.
connery-tdi
142
Essex
Have you got this fitted yet? Any problems with battery drain? Any chance you could upload pics of how you solved the pin 16 issue. I've got an rcd 310 waiting to be fitted but not sure how to do it.
Lastly, is it possible to put an aux cable in the back of the unit? Thanks.
holmefield
Oct 20, 2013
578
As to the battery drain I dont think mine will have it as its an 08 57 plate which I believe meansit doesnt suffer from battery drain??? But I could be wrong..
Im fitting it all together this friday so I'll post when its done.
connery-tdi
142
Essex
I put mine in last night just to check I could get it to work. Managed to get it working, more luck than judgement. Just need to get the fascia, aerial adapter and aux cable and I'm sorted. Unless it suffers from battery drain. Although I have a new can gateway ready just need to find someone that can programme it in for me.
holmefield
Oct 20, 2013
578
Did your Aux port work ok when you plugged it in???
I've posted a Aux pin assignment list in a different thread to try and find some answers?
Its call Headunit upgrade
connery-tdi
142
Essex
My car is a very basic 06 model that didn't even have aux to begin with. I have had a play with the headunit and found an option for aux in it. So I have assumed it should work of with an adapter I have ordered from eBay. Can update you once fitted.
holmefield
Oct 20, 2013
578
Right my rcd310 is going in on friday and my car ( which is an 08 57 plate ) now I know that pin 16 ( safe pin ) needs a power feed, I use my Aux port alot which is the standard factory one down by the handbrake from what I've read it isnt going to work once wired in to the new Rcd310...
What wiring do I need to re-root/alter in the back of the block that fits into the head unit please?
Is it in the same block as were pin 16 is? Whats involved do you have to add a wire or do you have to move the Aux wire to a spare pin ?
Any help would be greatly appreciated. ..
holmefield
Oct 20, 2013
578
Right I've been doing some Ebay hunting and is this the page that explains what to do with the Aux wire re-rooting? I've linked to two pictures that show what goes where, but some help off a member would be a big help to explain which wires need changing.????/
Volkswagen RCD 310 pin assignments
volkswagen_rcd_310_rear_N91-11040
1. Aerial Connector
DAB aerial input connection, optional
or
SDARS aerial input connection for vehicles for USA and Canada
2. Multi-pin connector 1, 8-pin, for loudspeaker outputs
http://i1.wp.com/www.my-gti.com/wp-...gen_rcd_310_rear_N91-11040.gif?resize=251,300
volkswagen_rcd_310_main_N91-100161 – Rear right loudspeaker, positive
2 – Front right loudspeaker, positive
3 – Front left loudspeaker, positive
4 – Rear left loudspeaker, positive
5 – Rear right loudspeaker, negative
6 – Front right loudspeaker, negative
7 – Front left loudspeaker, negative
8 – Rear left loudspeaker, negative
3. Multi-pin connector 2, 8-pin, for voltage supply lines and CAN bus
http://i0.wp.com/www.my-gti.com/wp-...gen_rcd_310_main_N91-10016.gif?resize=300,243
9 – CAN bus, high
10 – CAN bus, low
11 – Display voltage supply, positive
12 – Voltage supply, negative, terminal 31
13 – Display HV CAN bus low
14 – Display HV CAN bus high
15 – Voltage supply, positive, terminal 30
16 – Anti-theft coding control signal, SAFE, positive
4. Multi-pin connector 3, 12-pin, for telephone and microphone signals
1 – Microphone input, negative
2 – AUX output, audio, right
3 – AUX output, common signal earth
4 – Microphone output, negative
5 – Telephone audio input signal left, negative
6 – Telephone audio input signal right, negative
7 – Microphone input, positive
8 – AUX output, audio, left
9 – Microphone output, positive
10 – Telephone mute (mute switch for radio)
11 – Telephone audio input signal left, positive
12 – Telephone audio input signal right, positive
5. Multi-pin connector 4, 12-pin, for CD changer control and CD audio input signals
1 – AUX signal input, left
2 – AUX signal earth
3 – CD changer, audio signal earth
4 – CD changer, voltage supply, positive, terminal 30, contact continuous load greater than 1 A, temporary peak load 5 A
5 – Not assigned
6 – CD changer, DATA OUT
7 – AUX signal input, right
8 – CD changer, left audio channel, CD/L
9 – CD changer, right audio channel, CD/R
10 – CD changer, control line, switched positive
11 – CD changer, DATA IN
12 – CD changer, CLOCK (internal check protocol for data flow monitoring)
connery-tdi
142
Essex
You started in this yet? How's it going. I think my cables have arrived today so hope to. Get them fitted tonight. Should receive my fascia tomorrow too!!
