bahaa_monier
Hi guys ,
i bought new leon ,
i paired my iphone to it,
but i need to connect another telephone ,
can i know how can i reset bluetooth in my car ,
or how can re-pairing my new telephone ?
please help !
Just go through same pairing process again.
I think the car can take upto 3 Sims/phones at a time. You can only use 1 at a time though I think.
When you have both phones paired, whichever has the Bluetooth turned on should hook up.
Good luck!
i deleted my paired phone ,
so when i research i can't find it or another one
can help how can i reset bluetooth settings in car or how can re-pair my phone, ?
i tried to press on all buttons for while but nothing
waiting help please
only thing i can suggest is turn off Bluetooth on your phone.
Sit in car & turn bluetooth back on on your phone.
Search for devices.
Think shows up as Leon UHT or something
Select this.
Should then be asked by phone if you always want to connect when this device detected. Select Yes.
Phone should then pair with car.
It may take a few minutes for details/numbers from you Sim to be downloaded to the car.
Hope this helps & not just telling you what you have already tried!
I tried everything , but no way ,
i need to know how can i reset my bluetooth in my car to re-pairing ,
will it if i disconnected the battery ?
is it safe ?
or cpu ?
can help please ?
is it safe ?
or cpu ?
can help please ?
Sorry I can't offer anymore advice than that.
Not sure if you're still in warranty but may be worth taking to Dealer to see if can check your Bluetooth module. I think it's located under the drivers seat.
I'm not sure about disconnecting battery.
Hope you get it sorted soon & sorry can't give you anymore ideas.
Have you got your phone set to be visible ?
Plus can your phone see the cars bluetooth when searching with your phone ?
I'm into same issue and need to reset my car bleutooth. I have tried with disconnect bluetooth (under passenger car front seat) during for a night - didn't work. After that I disconnected the battery (+) for another night - didn't work. In a friends BMW he have a small button do unpair car bluetooth. There must be some trick in Seat as well. Anyone that knows?
Thank you for the tip. Worth a try. Anybody who can confirm that this works?
Just had a quick glance through and I can't see what type of phone you're using! I had an issue with mine; I paired it, then disconnected it, and I could never reconnect it. Turned out it wasn't the car at all, it was the phone.
I have a blackberry bold. All i had to do was reset the phone (take the battery out and put it back in). And then it worked fine.
Doubt it will help in this circumstance, but it worked in my scenario.
Chris
Iphone 3GS w OS 4.0.1 (have tried OS 3.1.3 and 4.0) also tried to unpair, reinstall OS, updated settings, reinstalled settings, checked that my car have latest bluetooth version etc.
did you manage to get an answer, mine bluetooth has alaso just randomly stopped working.
Yes, I did solved my issue. Seat had no idea. The problem was that my Seat Freetrack was not able to handle all my contacts in Iphone Phone book. The car seems not to be able to sync that many contacts that iPhone can have (I had over 260 contacts). Is there more contacts the mobile tracking connection/transfer will be abrupt during transfer (I could see on the dash panel how the car counted the contacts during import and then suddently stopped at 260 contacts). Also if there are several contact groups in the phone it can cause problem when the car tries to sync the phone book. NOTE that some phone apps also add their own contacts, like TrueCaller etc.
Solution:
Since the car (Seat Freetrack 2008) has no button to remove synchronized phones. I did this.
1. Turned off bluetooth on my iPhone.
2. Paired five other mobiles (the family's cell phones) to the car to have my iPhone forgotten in car memory (unsure if it helps to disconnect the battery to forgott the phones).
3. In my iPhone Phone Book I choosed to have just the most important contacts as "Favorites".
To do so go to: Settings > General > Bluetooth > Devices (choose SEAT_UHV) > Phone Favorites ON (and of course Sync Contacts ON to show favorite button) ALSO on the same screen choose "Other Groups" NONE (THIS IS VERY IMPORTANT ELSE SEAT WILL TRY TO INSTALL ALL CONTACTS).
4. Started Bluetooth and sync to my Seat.
5. Choosed to just import my few favorites in the cars during install process - NOT the whole phone book/all contacts - and it WORKED (and have done so all after).
PS The bluetooth unit are mounted under the front passenger seat.
PS 2 iPhone is NOT garanteed from Apple to work with other brands than their own. There is apps for this to use on jailbreaked iPhones (legal) but I don't think this is needed for sync with your Seat.
Hope this will be to any help.
No other phones will find it either though which is a nightmare. The other thing is that the steering wheel controls have totally stopped working in regards to the phone buttons. Also the iPod connection won't recognize any iPods it just plays with no sound or doesn't recognize it. Honestly is a nightmare but I do appreciates your detailed response mate.
Sorry, no. But the service manual can give a hint i guess, or the dealer maybe.
