worzel
LCR 225
Dec 20, 2009
366
Jersey
Hi, any LCR owners that have these, where did you get the droplinks??
I've got one, but no drop links supplied. I assume all rear ARBs need the drop links??
Dave at Sere said the only ones he could source would be for a 4WD Cupra...would these fit?
What make of ARB is it mate?
When I replaced my Neuspeed drop links I made some up by using a male & female rose joint with a lock nut. This is what the Neuspeed bars are supplied with. Buying the Neuspeed ones is massively expensive, i think it was around £80 for a mounting kit.
Matt.
I don't think all rear ARBs have drop links? I think only adjustable ARBs have drop links but I could be wrong? When I fitted a Eibach rear ARB to my MKII Golf it didn't need drop links but my Nuespeed adjustable one did. Where did you but it from and what make is it?
H&R rear ARB, came in a kit inlcuding the front ARB from Awesome. Remembering its shape it is possible it doesn't need the drop links. I did think it strange that it came with everything but no drop links in sight, probably because it doesn't need them. It has been suppled with the bolts though.
Think i'll get under the car and see it will fit with just the bolts, failing which I will call them as you suggest
