Rear Axle Bushes
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
Just want to ask if you can change these easily without the tool, or if anyone has done this to there car and what they done and if they had any problems? Thanks
L16YDW
Big Beefy Boy
Dec 1, 2014
157
Norfolk
Easy if you fit poly bushes, need tool if fitting stock.
Unbolt axle at the pivot bolts and shocks, disconnect brake pipes. Drop axle off. Cut old bushes through open voids then cut the sleeve out with a hacksaw. Lube up the poly bush and hit it home with a rubber mallet or Metal hammer and a lump of wood. Bolt it all back together and bleed brakes.
It's all the same if you are fitting standard bushes apart from pulling new bushes in with the tool.
Bigjohn84
May 5, 2015
2,330
Yeh I know how to do it just wanted to know if I defo need that tool, and if there's any problems I need to watch out for
Bigjohn84
May 5, 2015
2,330
There's about 3 different types for the rear axle bushes some thick some slim, the ones above are they the correct ones for my car, 1.8 AUQ Cupra
Bigjohn84
May 5, 2015
2,330
Hears what mines looks like
AmD Stage 1 Map, Forge 007 DV, CDA Induction Kit, GT80 Milltek Cat Back.
