Went to change the brake discs and pads all around this morning only to find I do not have the right size allen key to remove the rear calliper carrier. Is it a 7mm one and if so, where can you buy them as I can only find 6 or 8mm ones?
On the fronts, is it a case of popping off the plastic caps and using the same size allen key to remove the front callipers?
