Rear callipers sticking
Steely
semiskimmed cupra R
Dec 30, 2008
1,425
Doncaster
I stand corrected then ! :) I could of sworn , I'm possibly confusing with a previous car, that's going
To bug me now ! Well until I next have the rear calipers off.
Feb 22, 2009
3,469
South Wales
for those wanting numbers taken from another thread on here
From Briskoda
30771.attach
http://www.briskoda.net/forums/topic/137832-handbrake-cable-issue-on-my-vrs/page__st__30
Part Numbers are in there too
Part numbers
7HO 615 295A (near side)
7HO 615 296 (off side)
Total price inc VAT was £3.91 from TPS
will be ordering some this week
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The handbrake mechanism works by pushing the piston against the pad using a rod that goes up the middle.
When the handbrake is off, the same piston is pushed against the pads by the brake fluid, under pressure from the pedal and the vacuum servo. The handbrake rod is threaded, and the piston climbs up the thread a little bit every time the footbrake is operated, adjusting for pad wear.
http://www.autoshop101.com/forms/brake06.pdf
http://20v.org/lucas_caliper_rebuild_instructions1.jpg
http://20v.org/lucas_caliper_rebuild_instructions2.jpg
The rods are threaded the same way on each side. There is no need to make them opposite threads, as the thread is just a spiral ramp used for self-adjusting, and not to activate the handbrake.
Dec 25, 2009
1,531
Just fitted them, takes 5minutes if that. Helps the calliper arm release fully. Thanks for the parts numbers dude ;)
