Rockbox
168
56
Hi,
Just wondering if anyone out there has recently changed their rear Dampers on a Leon.
I need a pair for mine but it keeps coming up with two different sizes so was wondering if someone either knows the size or can measure it.
The two sizes are 11/45 and 13/45 .
The 45mm is the width of the eye and the 11mm or 13mm is the diameter of the pin.
My car is a 1.4 tsi 150bhp FR SC with non electronic suspension and a rigid rear axle.
On some sites it mentions pr codes I've look in the boot at the sticker but don't know what code relates to what.
I was looking at getting either Bilstein,KYB or Monroe one's if anyone can help with part numbers.
Thanks.
There are loads of OE variants of springs and dampers.
If you give me your reg or VIN I can tell you what damper part number is for your car, or just give seat parts a ring and they will also tell you the price.
Those other brands you mentioned are aftermarket and will probably only have 2 version like sport and normal so just go via their own catalogs.
