Rear discs
Apr 1, 2022
Has anyone had an issue with one or more of the rear brake discs? My off-side one has significant warpage (23000) miles but the near-side doesn't. Front discs have no warpage but a bit of scarring. Pads just replaced recently on front but dealer suggested new rear discs before replacing those pads.
380bhpdaily
1,261
574
Yes, almost every day. Not had the car 24 months yet.
That’s strange that the disc has done that especially on the rear disc. But be really badly warped if they spotted it on a service as they won’t remove the rear wheels to check the brake it’s a visual check and a gauge is used to measure the inner pad.
Maybe get them done and monitor again that’s all I can suggest sorry.
jt20vt
190
46
Others have had similar issue with the mk3 leon cupra, uses same setup. Issue with disc warping. I've had it on my mk3 cupra st also. Supposed to be a different brake pad with revised part number out to stop it happening.
