Rear Door Lock Repair?
ozzymyster
234
Hi All
Have a problem with my rear right door. Locks sometimes and not others...Does sound like its on the way out, groaning sound coming from the door..
Can these parts be taken apart and repaired? Looks like something youd never get back together
Have this link but parts look different
Brian
Jack Smith
Those parts must be replaced not repaired so hire a locksmith to do that . Also, Before choosing any locksmith service provider it is always best to consult your family members or friends firstly. The first thing you should look for in a 24 hr locksmiths service provider is whether he is licensed or not.
Bouncerbeater
Old enough to know better
Mar 15, 2013
1,303
Gloucestershire
Why on earth would you hire a locksmith to do a fairly simple repair with replacement parts?
Not by any chance a " locksmith" are you ? :lol:
747_727
1,113
Essex
They are only £20 on eBay so I'd just replace it. I've replaced both front locks and now both rears are playing up.
sockpuppet
837
Locks are a common fault on these cars, try spraying wd40 in the mechanisms of all 4 locks then lock and un lock using the 2 buttons on inside drivers side door about 50 to 100 times and see if that gets them working again. The back door locks are more difficult than the front to replace as you have to drill/punch out the disc that connects the window mechanism to get the window out to get to the lock. You can get the chinese locks for about £30 or the genuine for about £130 a piece.
If the lock jams shut get someone to press the unlock button on the drivers inside door panel while you bash the lock handle repeatedly with your hand and eventually it will unlock.
Timcruise
USA
Crystallake locksmith Service coverage ensures that they can provide a one stop solution for all your locksmith requirements. With 24 hour availability and an average response time of just 2 hours for their commercial clients,they provide a reliable and professional locksmith service no matter where you are.
65coupe
I'm too old for this!
Sep 8, 2007
194
Southampton
I doubt you'd manage a 2 hour response time given that you are in the USA and the OP is in the UK :lol::lol:
Besides, he really doesn't need a locksmith - he's clearly mechanically minded enough to get the existing lock mechanism off so he should obviously be able to replace it with a new unit. Like others have said, they're only £20-30 off eBay and work fine!
LOL just seen the original post is nearly 4 years old - he's probably replaced the lock by now
Homer Simpson
229
22
While the door still opens, change the mechanism. You will kick yourself later if it fails and the door is sealed shut.
