jacko5
187
35
61
UK
Well my rear electric windows have stopped working on my Seat Leon FR Diesel 2009.
When i press the lock unlock switch on the front drivers door switch nothing happens at all.
I have checked with Vag com and they are enabled ( thought i would check as i did some vag com messing ).
Fuse is ok ( checked fuse 26 ).
Another weird problem that has appeared at the exact same time is that the front electric windows have swapped round on the 2 operating switches ( so the outer switch opens the passenger window and visa versa ).
My passenger side rear window is slightly open and i cannot close it from the rain.
Any way of shutting the rear window manually ?
Desperate to sort this out, anyone have any ideas ?
Thanks.
Edit.
The door mirrors are also operating the wrong way round with the center console switch that operates the door mirrors.
This is weird.
Sounds a bit like a central convenience unit problem. I think it's located in the driver's door.
Sent from my XT1072 using Tapatalk
Thank you.
Do you know what unit i am looking to exchange ?
Has anyone a picture of the offending unit ?
Thanks.
Don't have a picture but my dad had similar issues on his 56 are altea and had the unit swapped under warranty. They were a bit flaky on the previous facelift and mk5 golf.
Ok thank you.
Edit,
Took the battery lead off for 20 mins this morning.
When i put it back on it allowed my to close the rear window with the rear window switch, so at least the panic is over.
The front window switch that operate the rear windows still do not work though.
