Rear number plate light housing
Simon_88
Hi all.
I noticed this afternoon my rear number plate light was hanging down. When I took a look and tried to fix it, I noticed that a little bit must have broken off meaning it won't stay in place.
I was wondering where I can buy a replacement housing for the bulb, or would I be better off getting LEDS (if so any recommendations)
Many thanks,
Ps I got a 61 reg leon fr.
Speed-FReek
1,110
18
United Kingdom
If you mean number 15 in the diagram below then the part number is 3D0943021A and it is currently listed as ~£8.50 for a pair.
Simon_88
That looks like the one! Thanks!
Just while I'm here, where did you find that info? Might save me from posting daft questions again?
Thanks,
Stylance
Stylance
Apr 6, 2011
647
Ashford kent
I purchased LED ones on eBay, no codes and they look good!
Sorry but cannot remember which item or seller either. But they were around £20-25
-staytuning|staymodified
Speed-FReek
1,110
18
United Kingdom
Interesting. Were they the complete housings with incorporated LEDs, or just LED festoon bulbs put into the original housings?
Looks like you have a facelift car. Are you getting any bulb warning errors on the dash? The facelift cars are notorious for this even with error-free CAN BUS LEDs so I would be interested to know if you've experienced this issue with yours and/or if you've done anything to get around the problem (such as fitting additional compensating resistors).
Stylance
Stylance
Apr 6, 2011
647
Ashford kent
No problems what's so ever! They are complete units, you get a plug, plug it in.. Leads to a resistor then that leads to the whole unit, tuck it in, pop the whole bit in, and job done! I'll try find some on eBay now.
Stylance
Stylance
Apr 6, 2011
647
Ashford kent
... Think it was these
eBay no. 221641277396
BennyP478
15
Birmingham
the exact same thing happened on my Leon FR FL the clip had broke, ended up taping it on until I got these through the post. (unable to put as hyperlink not enough posts yet :()
Ebay Item No. 361095786027 £17.98 Free P&P
straight swap out with plug and socket with no errors on the dashboard. hope this helps. :thumbup:
Jun 25, 2012
920
Gateshead
Just replaced mine with these eBay num 131150100415 . no errors , ones above are a few quid cheaper ( even better )
