Rear vented 256mm brakes
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
i do :p, but they need milling down from 256mm to 250mm plus uprated calipers to audi s4's
heres old vs new
Tunerko
Seat ibiza 6K TDi PD swap
Oct 5, 2009
10
Bratislava, Slovakia
Hm interesting, I plan to give a komplet set of rear brake Octavia RS
I have a complete rear axle
Ihave now back homemade discs 286x10mm
Do you have any photos of the installation?
what diameters of rear disc have a S4?
and whats the wheel hub, ist original 6K or??? fit the ventilated disc on original hub??
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
the car is on standard hubs only thing that has to be done is to take the back plate off due to the vented discs been bigger. The discs that where used are mk1 audi tt brakes i think and audi s4 calipers all bolts nicely. calipers line stright up with the hub brake lines do not have to be altered just a straight swap over think it only took 1.5 hours to do the pair and blled the brakes
Tunerko
Oct 5, 2009
10
I am doing it for better braking performance
I ride mostly circuits and brakes must be tip top
I currently have 305x28mm Brembo front of Ibiza cupryR rear 286x10mm homemade non ventilated
256x22 mm is another step to better braking on the track ansd best times :)
chris_200120vt
MR carbon fibre
Oct 4, 2008
2,711
YEADON, LEEDS
256mm discs will not fit they have to be milled down to 250mm due to the calipers think i have around 2mm clearance from the top of the disc to the carrier bracket if you look at this photo you will see what i mean
