Rear washer leak
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
the rear washer is lossing pressure when keepin the rear wiper pressed. Seem to see water dripping from passenger side arch.
Any suggestion where about its leaking from and how to access it.
Thanks :D
Gwaredd
The pipe has popped off that runs inside the car. Simply take the 2 screws out that hold the plastic trim in place on the N/S floor/door. Pop the pipe back in & wrap some gaffer tape or similar around it to prevent it happening again. Should take all of 2 minutes.
Your carpet will be soaked though:shrug:
AD90
Gwaredd,
Can you explain "plastic trim in place on the N/S floor/door" I think I have the same problem. The rear nozzle was blocked it's now clear but no water?
Also does anyone know if the nozzles have solenoids? Or what is the wiring for?
AD90
