Rear wing/spoiler , how do I take it off?
Jul 25, 2021
10
So the left part of my rear wing has been wiggly and the 3rd break light's not working. So how do I remove it? Are there any hidden bolts I'm unable to see or what?
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,257
1,110
Kent
Open boot, you'll see 2 black plastic caps on the outer edges up near the hinges.
Prise those off and you'll find 2x 8mm nuts.
There's a third 8mm nut hidden behind the big plastic c-shaped boot trim.
Once all the nuts are removed you can close the boot again and lift off the spoiler.
There's an electrical plug in the middle which simply pulls apart.
Sent from my SM-S906B using Tapatalk
Reactions: Mr Pig
Thai-wronghorse
Dec 3, 2015
2,257
1,110
Kent
What bulbs or handles...you're supposed to be looking at the boor beneath the spolier
Jul 25, 2021
10
This is where I at , I see only 1 bolt at the center , I can't see those black caps you're talking about. Also thanks for taking time out your day to give tips
Jul 25, 2021
10
Thanks a lot , one of the parts that held the bolt was broken , which is why it was wiggling around.
