makes a huge difference mate pulls all the way 2 the red lineTrust me mate, you will be blown away! I still am hehehehe
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
340Nm???!!!!!! there is a guy on here from Greece I think who is running over 300Nm on his box and from what I believe has had no issues yet. .
Just to see the figures..
Yes, the box is what i´ve been worried about to, but how will the engine cope with the high boostpressure? Stock is 2,5bar max pressure. What i found out so far about the map is that they change the parameters for Boost, ignition, fuel and a gearbox upgrade of some sort..
Stock pressure is no way near 2.5bar, your turbine would have been blown up if that was true. With Stage 2 remap and the boost pressure is 1,55bar and 1,2bar @ the limiter.
The parameters you mentioned are being changed no matter where you do your remap, this is how you increase horsepower nothing new nothing to worry about.
Hmm, ok.. I don´t know where, but i read somewhere that the max boost is 2,5 and the average boost is 2,25 bar standard.. Might be completely wrong as you say, i´ll try to find where i read it..
Can us oil burners play in this thread?.....318.4Nm standard![]()
Mine is quick enough between the lights with my REVO and V-Power hehehehehehehhe
