djcTDi
86
London, UK
How easy is it to remove the screen wash reservoir?
I want to take it off so i can fit my HID ballast behind it instead of having it zip tied to the reservoir itself.
I had a quick look when I fitted the HIDs but its surrounded by screen wash pipes and I couldnt see any easy way of getting it out without breaking them.
Any one done this before?
Dan
Nope, found it easier to pull the undertray off underneath and fit the ballast to the underside of the bracket below the head light.
Its not hard to remove at all, two nuts IIRC. Also remove the black box that ticks right behing the washer bottle then you have a lot of room to install the ballast unit. Pull off the plastic wheel arch liner and you can get in that space from both sides.
