MDouglas9CR
I'm planning to replace the drivers seat on my Leon Tdi Sport with an OPG seat and harness. Reason for doing this is that factory seat is giving me back problems and either I change the seat or the car!
Has anyone already done this? Things I'm aware of..
1. Airbag in drivers seat must be deactivated.
2. Factory seatbelt can't be used -lock is built into seat so harness is required.
3. Seatbelt alarm for drivers seat must be deactivated.
4. Need to make a plate adapter to fit OPG seat onto the existing 4 floor bolts.
Looking at other threads, I've found that using VAS 5051/5052 diagnostic machine, I can sort out airbag and seatbelt. Thought I would post to see if any of you more learned types would spot anything else before I get started.
