Just want to to know if the AUQ 1.8t has one.......never took mine above about 5000rpm. Is it safe to do so ? Always use Helix Ultra 5w30 synthetic on CC stage 1 remap....changed every 5000 miles.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Not sure with these engines yet as I've not used one in anger, but the merit of revving it beyond the point of peak power is to remain in the power band when you change gear.
I'm sure these engines make a lot of power low down though.
Any tuner who remaps a car to carry the power right through to the rev limiter ain't much good in my opinion! 5500rpm and change gear, no matter if its tuned or not!!
Think your missing the point. Tuners don't solely decide where the engine is making its peak power, this is down to the characteristics of the engine and ancillaries. For example on NA carsa 4-1 manifold makes more power at higher RPMs.Why bounce of a rev limiter if there is no need too? Sure they are designed to stop you doing damage so its fine to do so provided your 10+ year old mk1 leon has no problems, and as for some Honda engines, im aware they rev out to 9000rpm + but this is a seat forum, specifically a seat Leon forum! so tell me why you would your 1.8t tuned to achieve its peak performance bouncing of the limiter?
