Davesimmons269
53
20
Hi,
I have the Check rear left reverse light warning, the light isn't working so was thinking of buying this LED light
Is this correct and would this work? I currently have a 2020 FR.
TIA
Reactions: ryc1
A W16W is the correct fitting, but if the reverse light is monitored by CANbus then you need a CANbus bulb or it will more than likely throw an error message.
You can also change the light bulb settings with VCDS to LED if you get a light bulb error after the replacement.
Would this be a UK MOT failure same as replacing a headlight with a non-E marked aftermarket bulb? (assuming the tester is following the regs to the letter)
Thanks for the replies, i think i will just get a like for like. What is the best place to get them from and which specific bulb is it please?
