ZiggyEP3
405
72
UK
The Revo Intake pipe I have has finally undone the bolt the holds it too many times and now the thread will not hold a bolt. The pipe now sits loose and I have no way of bolting it to the engine. Can they be rethreaded and if so how the :mad::mad::mad::mad: can it be secured so it doesn't come undone again. I've tried threadlocks both liquids and plastic etc but nothing holds. Surely im not the only one tokeep having this problem :cry:
I don't have this particular intake but maybe the one I have you can check if you can buy and is compatible with yours this type of holder:
Thanks I might get a couple of large jubilee clips for now at try and strap it to the engine for now with a bit of rubber so it does not scratch the intake pipe.
Reactions: Chris78
The holder that I send you it have a rubber around the collar and it keeps the manifold with a screw down from battery tray you have a hole there for a screw! Give it a try! It keeps mine stable!!
Lock tight the bolt it won’t come loose again.
Tap and die kit? Make a new thread and like 300 said use blue loctite to keep it on. Mine didn't come with a spring washer and the bolt came off I lost the spacer but bolted it directly to the engine with blue loctite and has held sweet since even without a spacer.
