Monkriss
Basically, my car went in for an MOT the other day and it failed on Emissions. This is only because they couldnt do an accurate reading.
If you press the pedal down and keep it in one position, the revs build up and once they get to 2500 revs, they let go of the pedal slightly and the revs drop off completely, so they push pedal down until revs get to 2500 again, and they let off slightly and it drops all the way down. You cant get it to stay at 2500, no matter how hard you try..
I have tried to; cleaned the throttle body
blocked off EGR
disconnected battery, did a vag test on computer and it didnt come up with any problems on the engine other than throttle position sensor, but that was straight after refitting and it went back to normal with no problems soon after.
Fixed any points that might be letting in air.
Because it has failed MOT i cannot drive the car to have it make new learns, which i might need now it has been cleaned?
The garage says it needs a new Throttle body. But the same garage said they had cleaned the throttle body, but when i had a look at it, it was filthy, but after a clean it looked to be in good working order.
also, the TPS is giving a reading, so i dont think it is that, that is failing.
any other ideas? i dont want to get a new throttle body (£300) if i dont need one. Might it be the actual accelerator pedal? can it be cleaned or serviced?
blocked off EGR
