burrell Active Member Nov 27, 2009 95 0 Falkirk Mar 20, 2014 #1 Upgrading the RNS 310 for an RNS 510. Is it a straight swap and everything will work? Steering wheel controls, MFD, Bluetooth, MDI etc?
Daniel M Blackbelts & Chickenheads Apr 18, 2013 2,866 7 Middlesbrough Mar 20, 2014 #2 Are you selling the 310? Everything else should work I would think, but someone else will give you a definitive answer.
burrell Active Member Nov 27, 2009 95 0 Falkirk Mar 20, 2014 #3 Not at the moment, just considering an upgrade. However I would sell it if I bought a 510.
Rob_Talisman MKII CR FR 170 FL Stage 2 Sep 2, 2013 811 0 North East Mar 21, 2014 #4 Yeah will be fine. I upgraded my 310 to a 315. I had to fit a dab Ariel as the 310 wasnt dab but that was it. Sent from my iPhone using Tapatalk
burrell Active Member Nov 27, 2009 95 0 Falkirk Mar 21, 2014 #5 Oh right do you have any info on how you fitted the aerial? I want the DAB to work but didn't realise it would need a different aerial. Sent from my Xperia using Tapatalk
Rob_Talisman MKII CR FR 170 FL Stage 2 Sep 2, 2013 811 0 North East Mar 21, 2014 #6 Only needs a different one if your 310 isnt dab already as mine wasnt Sent from my iPhone using Tapatalk
burrell Active Member Nov 27, 2009 95 0 Falkirk Mar 21, 2014 #7 Sorry I probably didn't make that very clear. I don't have DAB at the moment but if it was on the 510 I would definitely want it to work. Sent from my Xperia using Tapatalk
Rob_Talisman MKII CR FR 170 FL Stage 2 Sep 2, 2013 811 0 North East Mar 21, 2014 #8 ok, go through my prev posts mate i did do a guide as to how i fitted mine. if you get stuck shout.
