Mikeyfraser
142
Hi does anyone know if bluetooth is compatible with an RNS510 version A unit?
The bluetooth kit is all fitted as I bought it like that.
Mike
Yes Bluetooth is compatiable with the RNS510.
Is it not working? What kit does it have installed? (there should be a module under the drivers seat)
No it's not working. This is the bluetooth module that is fitted under the seat 5P0862335B. There is voltage going to the pin on the plug as I checked with multimeter with me been a sparkie.
Yup seen the module, should be the Harman one.
What year is your vehicle? You should be able to get to the config menu through the vehicle display in the dash.
Also the Bluetooth will be visible for a few minutes from when you first turn the Ignition on.
Also make sure the little antenna that should be connected to the box has not fallen off.
My car is a 2009 plate. Pre facelift. I don't get anything anywhere. When I press the phone button on the headunit it just mutes it. No it's not fallen off. I've had it out.
So you have the orange large display on your dash being pre-facelift?
Has it ever worked since you have had the car?
If it is muting it sounds like it has lost its configuration to say Bluetooth is fitted or the Bluetooth module has gone faulty.
Where abouts are you? I have a spare Bluetooth module and VCDS.
Yeah my display is is red/orange by the speedo. No it's not the garage fobbed me of saying it's not with every model but mine has it all fitted when I got it. I'm in fife mate. Yourself?
Garage obviously not wanting to deal with it. They are correct that every model did not have Bluetooth at that point but if you have the kit installed someone went for the option.
Ah not good, im in the West Midlands!
Okay, so in trying to work things.
When you turn on the vehicle and scan for Bluetooth devices on your phone im guessing you never see "Seat_BT" ?
I would then start to look at the Headunit, when you remove it you will have access to the main Quadlock connector. The HU should have a wiring diagram label on it.
Yu can then hopefully buzz them out.
It's not good. My uncle is down that way. Lol. No I e had the car now about 14months.
Nope I've searched for it. I have an iPhone.
Yeah I've seen that.
Buzz them out to where the pin output at the bluetooth module.
I wouldnt say it was a common problem.
But just like any other ECU it can break or get damaged. If it was just the antenna you would still get the Bluetooth menu in the dash display.
Ideally it would be handy to get VCDS onto the car and see if the module is visible when doing a auto scan.
I had done any auto scan before and posted it up. I'll see if I can find it just now for you.
This is the auto scan I done.
Code:
Chassis type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
01 - engine - status: OK 0000
03 - ABS brakes - status: OK 0000
04 - steering angle - status: OK 0000
08 - HVAC - status: OK 0000
09 - cent. Elect - status: malfunction 0010
15 - airbags - status: OK 0000
16 - steering wheel - status: OK 0000
17 - instruments - status: OK 0000
19 - CAN gateway - status: malfunction 0010
25 - immobiliser - status: OK 0000
37 - navigation - status: malfunction 1010
42 - door elect, driver - status: OK 0000
44 - steering assist - status: OK 0000
46 - central conv - status: malfunction 0010
52 - door elect, pass - status: OK 0000
56 - radio - status: malfunction 1010
62 - door, rear left - status: OK 0000
72 - door, rear right - status: OK 0000
77 - telephone - status: cannot be reached 1100
address 01: engine           Labels: 03G-906-016-BKC.lbl
part no SW: 03G 906 021 SC.      HW: 03G 906 021 AN
component: R4 1.9L EDCS G000SG 1438
revision: --H08-- serial number SEX7Z0H83130H6
coding: 0050071
shop#. WSC 66565 257 00032
VCID: 72E1CE786D7B258E927-8027
no faults found
readiness: 0 0 0 0 0
Address 03: ABS brakes (-----).        Labels: 1K0-907-379-60B
part no SW: 1K0 907 379 AD      HW: 1K0 907 379 AD
Component: ESP MK60EC1    H35 0104
revision: 00H35001
coding: 133B201209240002C80B04E8902000813400
shop#. WSC 04941 000 00000
VCID: 74EDC860D76F2BBE80B-8021
no fault code found.
address 09: cent. Elect.      Labels: 3C0-937-049-30.H.lbl
part no SW: 3C8 937 049 E.     HW: 3C8 937 049 E
component: bordnetz-SG       H54 2602
revision: 00H54000   Serial number: 00000005864137
coding: 81880F2F00041000431D00000000000000007F075C40000C0
shop#. WSC 06402 785 00200
VCID: 336F0B7C52E16C86591-8066
subsystem 1- part no:1P0 955 119 B     Labels: 1KX-955-119.CLB
component: wischer 300608 002 0601
coding: 00056208
shop#. WSC 06402
1 fault found
01504 - bulb for license-plate light (X)
012 - electrical fault in circuit - intermittent
freeze frame:
fault status: 00101100
fault priority: 2
fault frequency: 5
reset counter: 150
mileage: 51511km
time indication: 0
freeze frame:
ON
voltage: 11.85V
ON
ON
OFF
OFF
OFF
Address 15: airbags.     Labels: 5N0-959-655.lbl
part no SW: 5N0 959 655 A.    HW: 5N0 959 655 A
component: J234_A03 VW10 HI  1815
revision: 19013000.   Serial number: 0039DPDP46T+
coding: 0012339
VCID: 3B7F235C7AB1A4C6811-806E
subsystem 1 - serial number: 6333FTS665711788
subsystem 2 - serial number: 6343FTS610751788
Subsystem 3 - serial number: 6353ETS6DFBQUVNH
subsystem 4 - serial number: 6363ETS6TUPLUVNP
subsystem 5 - serial number: 00000000000000000
subsystem 6 - serial number: 00000000000000000
address 16: steering wheel.      Labels: 1K0-953-549-MY8.lbl
part no SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
component: J0527   7520101
coding: 0002042
VCID: 840D18A0C7CF9B3E30B-80D1
subsystem 1 - part no: XXXXXXXXXXX
Component: E0221    002 0010
no fault cod found.
address 17: instruments.     Labels: 1K0-920-xxx-17.lbl
part no: 1P0 920 947 B
component: KOMBIINSTRUMENT V03 0750
coding: 0002401
shop#. WSC 18069 210 95564
VCID: 32610E78ADFB658E527-8067
no fault code found
address 19: CAN Gateway.     Labels: 1K0-907-530-V3.clb
part no SW: 1K0 907 530 Q.  HW: 1K0 907 951
component: J533_Gareway    H16 0202
revision: H16    Serial number: 2700K087100971
coding: E9807F064006020203
VCID: 356B35645C9572B6775-8060
3 faults found
01303 - Telephone transceiver (R36)
004- no signal/communication
Freeze frame :
Fault status: 01100100
Fault priority: 2
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
01300 - control module for navigation with CDROM (J401)
004 - no signal/communication - intermittent
Freeze frame:
Fault status: 00100100
Fault priority: 2
Fault frequency: 254
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
01304 - radio
Freeze frame:
Fault priority: 2
Reset counter: 151
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:20:00
address 25: immobilizer.      Labels: 1T0-035-680.clb
component: IMMO      V03 0750
shop#. WSC 00000 000 00000
no fault codes found.
address 37: navigation (J0506)     Labels: 1T0-035-680.clb
Part no SW: 5P0 035 680 A       HW: 5P0 035 680 A
component: RNS-MID     H05 1036
revision: AB001001     Serial number: SEZ6Z7L9137058
coding: 0C000440040200030020
shop#. WSC 00829 210 91891
VCID: 2C5D10004FDF337E18B-8079
4 faults found
00880 - connection to speaker rear left
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
00856 - radio antenna
011 - open circuit - intermittent
freeze frame:
fault status: 00101011
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault status: 01100000
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
00862 - antenna for GPS navigation (R50/R52)
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189km
time indication: 0
date: 2000.00.00
time: 17:32:14
Address 42: door elect, driver      Labels: 1K0-959-701-MAX3.lbl
part no SW: 1T0 959 701 L          HW: 1K0 959 793 P
component: J386   TUER-SG FT    1518
revision: 71009005      Serial number: 00000295288510
coding: 0004784
shop#. WSC 00829 210 97507
VCID: 408554B01357C71ED43-8015
address 44: steering assist         Labels: 1Kx-909-14x-44.clb
part no: 1K0 909 144 C
component: EPS_ZFLS KL. 77     2301
revision: 00H15000
VCID: 2A511618852B2D2D4EE7-807F
address 46: Central conv.       Labels: 1K0-959-433-MAX.clb
Part no SW: 1K0 959 433 BT     HW: 1K0 959 433 BT
component: KSG PQ35 G2   020 0204
revision: 00020000     Serial number: 00000000000000
coding: 198000405283CC7F7F00850560085F86F07C00
shop#. WSC 00829 210 90032
VCID: 830F1BBCC2C19C06091-80D6
subsystem 5 - part no: 1P0 951 171
component: innenraumueberw.010 4971
coding: 00000000
shop#. WSC 00829
subsystem 6 - part no: 1K0 951 605 C
component: LIN BACKUP HORN H03 1301
subsystem 7 - component        NGS n.mounted
1 fault found
01135 - interior monitoring sensors
freeze frame:
fault status: 00100100
fault priority: 4
fUlt frequency: 2
reset counter: 151
time indication: 0
address 52: door elect, pass      Labels: 1K0-959-702-MAX3.lbl
part no SW: 1T0 959 702 L        HW: 1K0 959 792 P
component: J387   TUER-SG BT    1518
revision: 71009005      Serial number: 00000278388505
coding: 0004784
VCID: 418351B4185DCE16DBD-8014
no fault code found
address 56: radio (J0506)      Labels: 1T0-035-680.clb
4 faults found
freeze frame:
fault priority: 5
fault frequency: 1
reset counter: 126
mileage: 51160km
time indication: 0
Freeze frame:
fault priority: 5
fault frequency: 2
reset counter: 149
mileage: 51568km
time indication: 0
Freeze frame :
Fault priority: 5
Fault frequency: 1
Reset counter: 142
mileage: 28528km
time indication: 0
date: 2000.00.00
time: 21:16:46
011 - open circuit
Freeze frame:
Fault priority: 5
Fault frequency: 18
Reset counter: 112
mileage: 30189
time indication: 0
date: 2000.00.00
time: 17:32:14
address 62: door, rear left         Labels: 1K0-959-703-GEN3.lbl
pert no SW: 1K0 959 703 AF      HW: 1K0 959 795 S
component: J388  TUER-SG HL    1401
revision: 11006001     Serial number: 00000003318110
coding: 0000144
VCID: 74EDC860176F2BBE80B-8021
Address 72: door, rear right       Labels: 1K0-959-704-GEN3.lbl
part no SW: 1K0 959 704 AF      HW: 1K0 959 794 S
component: J389   TUER-SG  HR    1401
revision: 11006001     Serial number: 00000003328954
coding: 0000144
VCID: 75EBF5641C1532B6B75-8020
no fault code found
Address 77: Telephone
cannot be reached
Excellent.
Right so the faults that are showing are just simply that you removed the Qualock connector from the back of the HU.
Looks like it cant see your Bluetooth Module under the seat.
I will try and get the Pin Details for the connector going to it when i get home. You can then check the CAN wiring to the Bluetooth module and check they are okay.
Either that or the Bluetooth module has broken/faulty.
Just do that by buzzing it out? Okay. At last someone willing to help me out. If you could that would be great mate.
By any chance do you know much about the reverse camera with this headunit? I put an rgb converter in with a yellow video plug from the camera in.
Got distracted yesterday. Will pull them up shortly for you to look at.
As for camera, have you installed one or is that what you are looking to do also?
My RNS315 has a 26pin Black quad-lock connector that's used for camera input. Unsure is the 510 is the same?
No worries. The camera is already fitted. Yeah so does mine but I had to by the converter to change the signal of the video to RGB so can connect it to the 26pin connector.
