Roundup of Details
jonjay
50 Years of 911
Jun 27, 2005
5,842
Essex
Thought i'd post of the details I have done over the last year. Used a fair few products so for people interested have a look at the various results to see which you like best.
mk1 Seat Leon Cupra 20VT
http://www.seatcupra.net/forums/showthread.php?p=2092578#post2092578
mk3 Seat Ibiza Cupra 20VT
http://www.seatcupra.net/forums/showthread.php?t=194346
mk1 Seat Leon Cupra R
http://www.seatcupra.net/forums/showthread.php?t=195712
mk4 Seat Ibiza 20VT
http://www.seatcupra.net/forums/showthread.php?t=209622
mk1 Audi A3 20VT
http://www.seatcupra.net/forums/showthread.php?p=2341852#post2341852
Chevy Camaro SS
http://www.seatcupra.net/forums/showthread.php?p=2374875#post2374875
Pug 106 Turbo
http://www.seatcupra.net/forums/showthread.php?t=218668
http://www.seatcupra.net/forums/showthread.php?t=227970
Ford Escort Cosworth
http://www.seatcupra.net/forums/showthread.php?t=231261
2008 BMW 320D
http://www.seatcupra.net/forums/showthread.php?p=2644587#post2644587
jonjay
50 Years of 911
Jun 27, 2005
5,842
Essex
mk1 Leon Cupra R
http://www.seatcupra.net/forums/showthread.php?p=2603869#post2603869
mk3 Ibiza Cupra 20VT
http://www.seatcupra.net/forums/showthread.php?p=2599252#post2599252
mk3 Golf Tdi
http://www.seatcupra.net/forums/showthread.php?t=232906
Products - Here are my fave so far
Wash: Dodo Juice Born to be Mild
Wheel Cleaner: Valet Pro Bilberry Wheel Cleaner
Wheel Sealant: Chemical Guys Wheel Guard
Glass: Lusso Glass Polish
Dressing: Valet Pro - Protectant
Polish Compound: Menzerna 106FA
Prewax Cleaner: Dodo Juice Lime Prime
Wax: Collinite 476s
Liquid Sealant: CarLack Nano Synthetic Care
Spray Sealant: Dodo Juice Red Mist
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
Some great work there.
Didn't have chance to look at all of your threads but how hard do you find the paintwork? I need to do my paintwork sometime (dealer made hash of it) and need to know what pad to start out with.
Will be using Menzerna IP (one of the older ones though) and a Porter Cable.
jonjay
50 Years of 911
Jun 27, 2005
5,842
Essex
Cheers,
Depends which paint work your refering to. VAG paint, more specifically SEAT paint is hard but certainly not as hard as BMW paint.
With a heavy polishing pad and menzerna 106FA you can get pretty good results if you work on small areas, make sure the polish is broken down properly and finally burnish the finish to get a good shine.
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
Sorry, it is VAG paint. 56 plate Ibiza. Have worked on BMW paint.
I had a go a few weeks ago and thought I did a good job, but think I only really burnished the surface tho as the paintwork relfections look much nicer but you can still see some deep swirls in good light.
jonjay
50 Years of 911
Jun 27, 2005
5,842
Essex
Trying working on smaller areas. With experience you will learn the working times of the polishes, what speed you should be using and what cut to get those deeper swirls out.
DetailingWorld is a good place to start. :)
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
I think I need some new pads TBH. Tend to use the smaller spot pads as prefer working with them.
I go on DW occasionally, actually been a member since Oct 06 but found it's got quite clicky over the last 18 months or so, so more of a lurker these days.
jonjay
50 Years of 911
Jun 27, 2005
5,842
Essex
Different pads yield different results on different polishes. I have 3 sets of pads for one polish as I get 3 different results.
Menzerna Polishing Pad is a good heavy polishing pad to get out light to medium swirls
Sonus DAS 6 SwirlBuster is a good compounding pad. It is not as hard as Menzerna Compounding Pad
Menzerna compounding pad is just to hard for my liking so I only ever use it for deep scratches.
Sonus DAS polishing pad is a good for light cutting compounds and cleaners.
Lake Country Polishing pad is a good alrounder and same with their cutting pad.
The new Hex pads are meant to be really good not tried these yet...the 3M pads are meant to be quite good to. I have 3M spot pads and they work flawlessly.
Davidsr
PD 172
Mar 13, 2009
207
Blackpool
I think I have the Menzerna polishing pad. Is a very hard white 6" pad. Used it on a BMW with some decent results.
I know Serious Performance were selling some pads off so may get some new ones from there.
Thanks for the help.
jonjay
50 Years of 911
Jun 27, 2005
5,842
Essex
Lookin forward to a new year detail :) Its really getting under my skin not having any time to give it some tlc :'(
Look forward to it too Mike.
I been quite bad recently the car is filthy but the good thing is she is all sealed so she should be ok once washed.
