Rs4 return valve.
Kdawg7
26
Has anyone who has changed their fuel return valve for the RS4 fuel return valve, noticed a visual difference when swapping parts. I’ve ordered one and cant physically see any difference. I expected to maybe see the ports slightly bigger. Unless the difference is internal..?
Rusty2k
713
137
I would assume it's just the strength of the spring inside that's different
Kdawg7
26
from what I’ve read recently online checking both part numbers, (which are almost identical). They both withstand same amount of bar.
Rusty2k
713
137
R8 / 2006 to 2008 RS4 pressure relief valve is 079130757
Mk2 Leon Cupra / Cupra R is 06D130757C
From what I've read before about it the standard one regulates to 130 bar and the RS4 one to 135 / 136 bar (reports vary)
Reactions: Kdawg7
Legojon
I only wanted a remap
5,316
2,748
I forget, but it's something like that. It was recommended for 2+ tuned cars because they were hitting 129-131 at peak power and releasing the fuel pressure early. I'm guessing they look the same, I got mine from AKS and they stamp the release pressure on the side of the valves - there's a higher one as well (160 I think) for higher stages.
