Right now im confused.... Those A/F ratio's were calculated by inserting my MAF readings into the calculation spreadsheet on the ross-tech website. http://www.ross-tech.net/vag-com/examples/air_fuel_EXAMPLE.xls
Is this not an acurate calcualtion of A/F ratio then?
Am i not actually running rich afterall? :confused:
Depends on the level of uncertainty on the ross-tech calculation.
ibiza sadly lacks the wideband lambda to properly measure the actual.
If you are in fact 13:1 you are not running excessively rich for under boost conditions.
Like you said, be really interesting to see how they compare with wideband logger.
I think Jonzy is gonna do a comparison with his Zeitronix and this calc. Be good to know for future referance.
Thanks for you comments Bill. So its not running overly rich then going by those figures? Not likely to damage my cat the way its running am i?
As you said Phil, i'd be intersted to see how the wideband readings compare.
Spoke to jonzy and aparently the logs show it to be slightly richer than it would be on the wideband.
Bill, what you make of mine...
Code:
RPM          LOAD        A/F
2400	41.4	15.72
2440	94	15.10
2520	135.3	14.25
2640	168.4	13.51
2800	189.5	13.01
2960	191.7	12.53
3120	191.7	12.02
3280	191.7	13.06
3480	191.7	12.79
3600	191.7	12.89
3760	191.7	12.63
3920	191.7	12.33
4080	189.5	12.37
4200	187.2	12.32
4360	181.2	12.14
4480	178.2	12.43
4600	173.7	12.17
4680	172.9	12.57
4800	172.2	12.18
4880	171.4	12.37
5000	172.2	12.16
5080	171.4	12.37
5160	169.2	12.45
5240	168.4	12.50
5360	165.4	12.30
5440	163.9	12.60
5480	166.2	12.47
5560	162.4	12.47
5680	160.9	12.64
5760	161.7	12.64
5800	162.4	12.80
Code:
RPM          LOAD        A/F
2400	41.4	15.72
2440	94	15.10
2520	135.3	14.25
2640	168.4	13.51
2800	189.5	13.01
2960	191.7	12.53
3120	191.7	12.02
3280	191.7	13.06
3480	191.7	12.79
3600	191.7	12.89
3760	191.7	12.63
3920	191.7	12.33
4080	189.5	12.37
4200	187.2	12.32
4360	181.2	12.14
4480	178.2	12.43
4600	173.7	12.17
4680	172.9	12.57
4800	172.2	12.18
4880	171.4	12.37
5000	172.2	12.16
5080	171.4	12.37
5160	169.2	12.45
5240	168.4	12.50
5360	165.4	12.30
5440	163.9	12.60
5480	166.2	12.47
5560	162.4	12.47
5680	160.9	12.64
5760	161.7	12.64
5800	162.4	12.80
nowt wrong with that under boost
someone should log with LCR on the ross-tech calc against actual lambda as it has wideband... be an interesting comparison
