I have found a little surface rust on the exposed areas under my MK2 and want to remove the wheel arch liners and treat with Dinitrol and re fit do they come off easily. Would appreciate any advice
Arch liners come off easy if you take the wheel off.
Ive not seen a rusty leon underneath and ive worked on quite a few over the years.
Bilthamber products are the best imo for rust,then just underseal/stone guard over the top
Jacked up front and removed most of liner only corrosion was in the unprotected area in line with the shocks and up to the macpherson mount PW it and will treat just going to put extension nozzle of rust proofer in behind liner and give it a quick blast.
