Mitchy you think thats a awful Power Band have a look at mine...
This was before my INA manifold and MBC...
boost 9 ,timing 8,fuel 7
im currently trying to sort it out though
We need to see some vagcom logs of requested and achieved boost. The awesome torque reading is way out. Providing your boost is staying within the limit of the map sensor (1.54bar) during peak spool i doubt you'll see much over 300 ft/lb if at all. the problem is some stage 2 cars are boosting way over this and people don't give it much consideration...... this is gambling with rods for sure.
Even if you use the most enthusiastic multiplication figures of 1.31 multiplied by peak air mass to give you bhp and then use this and the appropriate revs to calc the torque its still nowhere near the RR print out, but if people are happy then :funk:.
thanks carl.
Yeah Im not arsed with fiqures i just want it to be right....Simple Really..
il try and do some Logs soon...If its possible when i get it dyno'd could i log it on the rollers? to be safe...
I run the same code as you mate and i rate it highly. Your graph is the same as most, nought to worry about and the fact you have rods means happy days. The mani will do the business for you and i'm sure if you run the wmi she'll last too.
Yeah ive seen a Few Revo graphs like this....Seems to Feel more powerful with the MBC wired in does feel way better than the N75 controlling it...
Is it possible to log a car on a dyno?
