tsmiggy
138
Leicestershire
2015 Leon 184
I know there are a fair few threads about this,but the question is.........is it actually possible to update
this system,without getting ripped off.
Cheers Folks
I keep getting this error??
Did you update the maps? And if so, did you take a backup/copy of the existing files from when it worked?
Ok so you need to go to the backup files you took of the working card, and navigate to \maps\EEC\EEC_WLD and copy the OVERALL.NDS file from there to the same location on the card. You’ll need to overwrite the existing file on the card.
Make sure you don’t overwrite the backup files you have.
This is exactly what i done pulled the file from the backup copy (obviously copy and paste instead or removing it) still nothing
Make sure the folder structure is exactly the same - so when you open the SD card, it has ‘maps’ and then the folders inside are all the same.
Hi.My system is a 5FO .............and i see a download on the Seat Site,i also keep seeing something about MAPCARE,what is it and how do you know if you have it.
I'm sure 5FO is MIB1 and can't be updated with the workaround. It's also unlikely that you have 'Mapcare' if its a UK car.
I got the 2016/2017 update to work on my 2014 card on my 5F0, but when I tried the 2017 update it wouldn't work and that link is the newest update.
Yes but the files you can download now are the newer ones that I couldn't get to work. I emailed the company asked them if I could be sent the old files but they said no.
how did you get the old files to work on mib1 without mapcare ?
