PCV removal, it removes alot of hoses that are prone to splitting from under the inlet manifold. The only difference between those cans is the mounting position. If you mount the one you posted the same way I've mounted mine the inlets would be pointing to the left instead of the front of the bay.
Ask away mate, thats the main purpose of these forums.
You dont need to, I had a can fitted for a few month before I decided to do the PCV removal. The main reason I removed mine was a split hose.
If you look here:
you can see a blue pipe around the inlets, thats the 15mm pipe that came with the can. If you do this then the 19mm pipe you need will fit better over the inlets.
right so i need to order extra 19mm pipe or will the 15mm work that comes with it? wonna make shure i get the right stuff to do the job :)
Not sure the 15mm pipe will fit over the rocker cover breather and the oil filter housing pipe work, this is how mine use to be fitted befor the PCV removal:
I would wait until you have the 19mm hose to fit it.
bit of a update but no pics, got rid of the bmc cda and changed pipercross panel filter and smoothed,drilled airbox with a 3" feed and its loads better cant believe it, should have done it fron the start, also got rid of the carpet under the bonnet.
thinking of getting a mk4 golf or tt center sun viser, anyone done this?
