SD card not working
zatanna
Have tried micro cards, then got myself a transcend 64gb card which according to a pdf file which was sent to me by seat should work. When I put it into the car it says not recognised. So now using an 8gb kingston. It plays but not all files I copied over are showing in the list.
I have 1000 mp3's none in folders. Do they need to be in folders?
With the micro cards at least it showed up but there was a cross at the end of each song stating unplayable. So not to see some songs at all is odd and frustrating.
Jimbobcook
5,641
2,189
What have you formatted the card as? NTFS or FAT32 (MSDOS)?
Are all the files you copied over mp3 files and not some rouge m4a or wma files?
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,684
8
Caerdydd
If its not working at all then i would double check file system.. Are you sure its FAT32 and not FAT, or EXFAT? I imagine most 64GB cards are shipped in EXFAT
As for the specific files, they will be in an incompatible file format and will need converting
Jimbobcook
5,641
2,189
On my RCD510 I have some songs in folders and some not in folders still all works, mine wouldn't show the m4a files I had on there so I had to convert them all...
64GB is a big SD card to have in a car I always thought they were limited to 32GB... Could you check this with partition manager and set the card to only use 32GB in size...
Clazzer
429
Stoke on Trent
Not sure about the card slot, but the USB definitely works with a 64gb as I have one in the car and a 32gb card with no issues. Can't see why the card slot would not take a card of the same capacity as the USB.
zatanna
according to explorer it says fat32 I dont know the diff bet sdxc and sdhc but I guess I can google that. I wrote to seat and they recommend I take the car to a dealer. Maybe there is something wrong with the slot - I just dont know. Anyway I will try partitioning it if not then Ill check out SDHC, last resort dealer I guess.
TimSawf
864
South Manchester
SD cards are only up to 2Gb, SDHC from 4-32Gb and SDXC from 64Gb upwards. Not all units that take a SDHC will work with a SDXC. The early RNS 510 would only take a 2Gb SD card, the manual even stated that a SDHC card would not work in it.
Dan FR
Nov 14, 2013
1,684
8
Caerdydd
If it's definitely FAT32, then as above really, sounds like SDXC isn't supported and a 32gb SDHC card is your limit.
zatanna
Ok thanks this one I have says sdxc on it so Im doomed I guess. Will defo stick to 32gb for now.
Speed-FReek
1,110
18
United Kingdom
First of all, what model is your Media System and what software version is it running?
Also, where did you get the SD card from? There are countless Chinese counterfeit versions kicking around (especially on eBay) that don't actually hold the capacity they claim, or that shows up as available free space in the file explorer software. The result is that files on the card get corrupted which can cause all sorts of issues.
I have an RNS-315 in my car with Media System 2.2 software on and I have a Transcend 64GB Class 10 SDXC card working just fine with over 4000 mp3 files on it in various folders.
I did initially have issues because the card came pre-formatted with the exFAT file system and even with mp3 files on the Media System was complaining with a "Error: SD Card" message when inserting the card. I re-formatted the card to FAT32 and re-loaded the songs but still got the same error message. It was only after I used a specific FAT32 formatting software utility that I got the card to work.
Assuming you're running on Windows and not a poncy Mac I suggest you do the following:-
  1. Download the GUI version of "FAT32 Formatter" from this link and run it (click on the picture of the screenshot to download it, not the dodgy download button under the donation button which is just an advert image).
  2. Insert your SD card and select it's drive letter in the "FAT32 Formatter" program.
  3. Just use whatever default "Allocation Unit Size" the program puts in that box which depends on the card size.
  4. Click on the "Start" button and wait for the formatting of the card to complete.
The card will now have a proper FAT32 format file system on it.
Next, check the actual capacity of the card to prove that it's the capacity that it actually says on the tin by following the steps below (again, it's Windows only software). I always do this with any new cards I buy for peace of mind regardless of whether the place I bought them from has a good reputation.
  1. Download "H2testw" from this link and run it.
  2. Insert your SD card and select it's target drive letter in the "H2testw" program.
  3. Click on the "Write + Verify" button and wait for the test to complete (on large cards this can take some time so you have to be patient).
If the write and verify process completes having written to the whole card without any errors then you have a card that actually has the capacity it says it is so you know you are safe. If you get errors then you almost certainly have a counterfeit card which you need to return for a refund and then report the seller to eBay if that's where you bought it from to try and prevent other unsuspecting buyers from getting stitched up.
If the card capacity is good then load on some mp3 files, cross your fingers and try it in your Media System again.
One other thing to be aware of is that even with the card is properly formatted to FAT32, if there isn't at least one file on the card that is of one of the types supported by the Media System, then the Media System will display the message "Error: SD Card". So a correctly FAT32 formatted blank SD card will display that error message making you think there is actually a problem with the card itself when in fact it's just that there are no recognise music files on it. It would be nice if the Media System actually displayed a specific message telling you that files were missing rather than making you think there is a fault with the card itself but unfortunately it doesn't and you just get the standard generic error message.
zatanna
I realised it was indeed exfat - so I used your prog and its now fat32. I have not yet tried it but thanks for that even if it doesnt work I got it to fat32
