seat 1.6 lambda fault bse engine
2hot2trot
Hi all ,
I have an eml light on. done a quick scan with vag com and got these results.
Is it just a new pre cat sensor required or is something else at fault as this is the five wire type an not very cheap to buy.
would like to be 100% sure
VAG-COM Version: Release 607.3-UD
Tuesday,07,October,2008,13:28:13
Chassis Type: 1P - Seat Leon
Scan: 01 02 03 08 09 0F 15 16 17 18 19 25 36 37 3D 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: VSSZZZ1PZ6R013256
Address 01: Engine
Part No: 06A 906 033 FF
Component: SIMOS71 1.6l 2V 7004
Coding: 0000071
Shop #: WSC 06441
1 Fault Found:
19058 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit: Open
P2626 - 008 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 1472 /min
Mass Air / Rev.: 81.8 mg/str
Voltage: 5.100 V
Bin. Bits: 00000100
RPM: 1824 /min
Mass Air / Rev.: 92.6 mg/str
Voltage: 5.100 V
Bin. Bits: 00000100
Readiness: 0010 0000
Address 03: ABS Brakes
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441
No fault code found.
Address 08: Auto HVAC
Part No: 5P0 820 047 H
Component: Climatic PQ35 010 0201
Address 09: Cent. Elect.
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Coding: 008C0F2F00041000001D00000000000000007B075C
Shop #: WSC 06441
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Address 15: Airbags
Part No SW: 3C0 909 605 E HW: 3C0 909 605 E
Component: T8 AIRBAG VW8 027 2421
Coding: 0021560
Shop #: WSC 06441
Address 16: Steering wheel
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 634 0070
Coding: 0000002
Shop #: WSC 06441
Address 17: Instruments
Part No: 1P0 920 904 B
Component: KOMBIINSTRUMENT VO3 0618
Coding: 0000401
Shop #: WSC 06441
Address 19: CAN Gateway
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Coding: 3D0F0340070203
Shop #: WSC 06441
Address 25: Immobilizer
Component: IMMO VO3 0618
Address 42: Door Elect, Driver
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2352
Coding: 0000688
Shop #: WSC 06441
Address 44: Steering Assist
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv.
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC09000505485B863004CC
Shop #: WSC 06441
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Address 52: Door Elect, Pass.
Part No: 1T0 959 702 B
Coding: 0000688
Shop #: WSC 06441
Address 56: Radio
Part No: 1P2 035 152
Component: Radio BNO 0035
Coding: 0020400
Shop #: WSC 06441
End -------------------------------------------------------------------------------------------------
Thanx :)
tom fada
What was the eventual solution? My 1.6 Mk 2 Leon is showing up something similar and like you I'm reluctant to replace the oxygen sensor until I'm completely sure this is the problem. The code is as follows
19058 / P2626 - Oxygen sensor short to ground.
prezes_111
I have the same problem
1 Fault Found:
Freeze Frame:
RPM: 1472 /min
Voltage: 5.100 V
Bin. Bits: 00000100
RPM: 1824 /min
Voltage: 5.100 V
Bin. Bits: 00000100
What was the reason of this situation??
Could someone help me ??
tom fada
A quick update. I changed the front oxygen sensor at the weekend, cleared the codes and so far it seems to have solved the problem.
prezes_111
Thanks for your answer.
I've bought new sensor but not changed it yet. I'll give the information if it was the problem.
