2hot2trot
Hi all ,
I have an eml light on. done a quick scan with vag com and got these results.
Is it just a new pre cat sensor required or is something else at fault as this is the five wire type an not very cheap to buy.
would like to be 100% sure
VAG-COM Version: Release 607.3-UD
Tuesday,07,October,2008,13:28:13
Chassis Type: 1P - Seat Leon
Scan: 01 02 03 08 09 0F 15 16 17 18 19 25 36 37 3D 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: VSSZZZ1PZ6R013256
Address 01: Engine
Part No: 06A 906 033 FF
Component: SIMOS71 1.6l 2V 7004
Coding: 0000071
Shop #: WSC 06441
1 Fault Found:
19058 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit: Open
P2626 - 008 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 1472 /min
Mass Air / Rev.: 81.8 mg/str
Voltage: 5.100 V
Bin. Bits: 00000100
RPM: 1824 /min
Mass Air / Rev.: 92.6 mg/str
Voltage: 5.100 V
Bin. Bits: 00000100
Readiness: 0010 0000
Address 03: ABS Brakes
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441
No fault code found.
Address 08: Auto HVAC
Part No: 5P0 820 047 H
Component: Climatic PQ35 010 0201
Address 09: Cent. Elect.
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Coding: 008C0F2F00041000001D00000000000000007B075C
Shop #: WSC 06441
Part No: 1P0 955 119 A
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Address 15: Airbags
Part No SW: 3C0 909 605 E HW: 3C0 909 605 E
Component: T8 AIRBAG VW8 027 2421
Coding: 0021560
Shop #: WSC 06441
Address 16: Steering wheel
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 634 0070
Coding: 0000002
Shop #: WSC 06441
Address 17: Instruments
Part No: 1P0 920 904 B
Component: KOMBIINSTRUMENT VO3 0618
Coding: 0000401
Shop #: WSC 06441
Address 19: CAN Gateway
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Coding: 3D0F0340070203
Shop #: WSC 06441
Address 25: Immobilizer
Component: IMMO VO3 0618
Address 42: Door Elect, Driver
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2352
Coding: 0000688
Shop #: WSC 06441
Address 44: Steering Assist
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
Address 46: Central Conv.
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC09000505485B863004CC
Shop #: WSC 06441
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Address 52: Door Elect, Pass.
Part No: 1T0 959 702 B
Coding: 0000688
Shop #: WSC 06441
Address 56: Radio
Part No: 1P2 035 152
Component: Radio BNO 0035
Coding: 0020400
Shop #: WSC 06441
End -------------------------------------------------------------------------------------------------
Thanx :)
What was the eventual solution? My 1.6 Mk 2 Leon is showing up something similar and like you I'm reluctant to replace the oxygen sensor until I'm completely sure this is the problem. The code is as follows
19058 / P2626 - Oxygen sensor short to ground.
I have the same problem
1 Fault Found:
Freeze Frame:
RPM: 1472 /min
Voltage: 5.100 V
Bin. Bits: 00000100
RPM: 1824 /min
Voltage: 5.100 V
Bin. Bits: 00000100
What was the reason of this situation??
Could someone help me ??
A quick update. I changed the front oxygen sensor at the weekend, cleared the codes and so far it seems to have solved the problem.
Thanks for your answer.
I've bought new sensor but not changed it yet. I'll give the information if it was the problem.
