seat airbags>?!
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
ok so ive just put the tiger stripe seats in my car and there awesome BUT
they dont have airbags in them, how can i get rid of my stupid air bag light off?!
Apr 12, 2008
539
You should probably put in a resistor that will simulate airbag resistance. Not sure what resistance though.
smiffymk3
124
Aylesbury
if you know someone with vag com, they can be disabled...i had the same issue with mine when i put full leathers in form a golf vr6
if you put it through vag com as a mk4 golf, theres an option in convenience system for disabling airbags. run through that and disable them and then when you start the car up the airbag light flashes 5 or 6 times as an indication its disabled and then goes out
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
bingo. cheers duder!
cuprawill
Turbo lag is foreplay
Nov 20, 2009
703
You don't have to put it in as a mk4 golf. Just plug it in go to airbags there is a list somewhere of which one is which. Then you just set the value to 0 save and it's off. Did this on mine as I had buckets and harnesses. Was only left with the passenger Front airbag lol
Tucker157
1,066
Falkirk/Central Scotland
in the faq section theres a guide!!! http://www.seatcupra.net/forums/showthread.php?t=179359 , ive used it before, works well, jus use a full version of vagcom and code it off, ive done this before, but remember once an air bag is disabled the airbag light will flash when you start the car for about 15 seconds and will then go out. as supposed to not coding them off and it being on all the time.
