Seat Arosa Fuel Pump?
hewi1010
My girlfriend drove her car to work as normal the other day but when she came out that evening the car would not start. Essentially as soon as you turn the key the engine actually fires but then dies instantly. The AA man who came suggested it may be the fuel pump but couldnt be certain. i went and checked it out the other day and could hear the pump kicking in as soon as you switch the ignition on. I would have assumed that if it was the pump it would not 'charge' the fuel system at all. there is plenty of fuel in the car. the car has been running perfectly until now. And i am reluctant to send it to a garage and be hit with a massive bill if it is something relative simple
If anyone has any thoughts / experience of this i would be v grateful...
lunalupi
...is not a bloke!
Jul 29, 2006
953
Wiltshire
Has the fuel filter been changed recently - could be a blockage there preventing enough fuel from getting through to run the car, but enough through to let it start?
allallyouyou
Arosa Sport
May 23, 2006
292
In respect to the fuel filter it is at a higher risk of blockage if you let the tank run low/or even dry. Depending on the cars age would be an idea to change it as it wont break the bank.
hewi1010
HI Folks - thanks for the comments...
Looks like it was the immobiliser/ faulty key. Apparently a common enough issue.
Used the spare key and it started 1st time!
Cheers..
