Welcome, personally I wouldn't be put off by the mileage either, mine's done 64k on a 61 plate but everything feels tip top. I think these are fantastic used buys but I'm not expecting to be pleasantly surprised come resale time.
Hi, Thanks - nah its got full service history and hes doing the timming belt kit and water pump and a service.
It drove well, from the short distance I drove it so took a gamble and did the deal.
Got the Exeo earlier today love the build quality hooked the phone up with blue tooth the hands free works very well.
Only problem I think there is with it is when I first picked it up I'm sure I heard water like a gush no idea what so ever where it's coming from.
Can't wait to drive it to work tomorrow.
The Exeo badge on the back does it come off easy enough? I think it will look a hell of a lot better without it!!!
Glad you like it, treat it right and it should serve you well.
Rear letters are only stuck on so shouldn't be too difficult to remove.
Post some pics up when you can and sure you'll find plenty of ideas for mods on here to keep you busy [B)]
If you're hearing water slosh, then chances are the scuttle drain is blocked. Clear out the bio debris that is blocking it before your ECU gets swamped, and your feet get wet!
The letters come off the back easy with a little dental floss, I'm waiting on the weather to warm up a little before doing mine.
Where about is that where am i looking and i will go and have alook on my dinner. Thanks
Hi
I have had my 2013 Exeo ST CR Sport Tech for nearly 16 months and occasionally hear a slosh, this in my case is the fuel in the tank as I have the scuttle panel covered and check for water under there regularly and have never found it wet.
Best car I have bought, enjoy yours.
Hi
Hi mate, thanks, where abouts do you check to see if there is water near the ECU? or if there is water anywhere ?
Hi, look for water under the battery area, unless you have very small hands the battery needs to come out and for that you will need long thin extension bar and socket. I only found one drain on mine, under the brake servo next to the battery. I also hear fuel sloshing about on my ST, could be that, you are hearing.....Julian
Didn't hear the water flushing on way back from work but I have picked up on a few things.
when braking it pulls to the left.
Gearbox 2nd and 3rd feels ropey 2nd hard to get into gear and 3rd feels strange when the oil has warmed up it does get slightly better but doesn't completely go away!
Very good ;)
Just seems a little strange about this gearbox 1st to 2nd does seems stiff which I know can be a normal accurance but strange how 3rd is a bit ropey also. Can't hear any noise from the gearbox but that far away don't think I will be able to hear anything anyway!
130k on a 61 Se Tech ST, been pretty good, well put together, still have no rattles in the cabin, only issue with mine is the broken cupholder a rip off at £110 from the dealers!!!!!
1st to 2nd a bit rubbery when really cold, but frees up quickly, Rear wiper seized today, other than that, been really good, probably going to replace it with a Leon in a couple of months.
Mine is sometimes tough to get into first gear on cold mornings, but otherwise OK. Word of warning about the cupholders - don't let your drink condensate all over your plush RNS-e!
Sorry for double posting, but debadged pic as promised.
does look alot better will do mine over the weekend.
I have ordered the gearbox fluid recommened by FEBI yellow 75-80w so get that sorted see if it makes a difference 1st to 2nd and 2nd to 3rd lol keep you lot informed.
