benny12357
130
Swindon
This is my sisters car and it was parked in a field with long wet grass and we think it could have been hit by lightning, would anyone be able to look at these fault codes and see what they think it could be? The instrument cluster has already been checked and is all fine!
The first log is the original, the second was after all the codes were cleared.
Ben
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Address 01: Engine Labels: Redir Fail!
Part No: 03E 906 033 AA
Component: 1,2l/4V SIMOS3 00HS7002
Coding: 00031
Shop #: WSC 06402
VCID: 5FC83FF8DD26BD1
VSSZZZ6LZ6R077794 SEZ7Z0E3115963
4 Faults Found:
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
18058 - Powertrain Data Bus
P1650 - 35-00 - Missing Message from Instrument Cluster
18045 - Powertrain Data Bus
P1637 - 35-00 - Missing Message from Electric Load Controller
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 1110 0101
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 24589
Shop #: WSC 06402
VCID: 3C72A8742C70869
8 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
27-10 - Implausible Signal - Intermittent
01309 - Power Steering Control Module (J500)
49-00 - No Communications
01321 - Control Module for Airbags (J234)
01317 - Control Module in Instrument Cluster (J285)
01316 - ABS Control Module
01312 - Powertrain Data Bus
37-00 - Faulty
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 006A GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
VCID: F0EACC44B0B8B29
6 Faults Found:
37-00 - Faulty
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: Komfortger·t 0002
Coding: 00065
Shop #: WSC 06402
VCID: 3D74A570376A8F1
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: Steuerger
Component: t Beif. antwortet nicht
1 Fault Found:
79-00 - Please Check Fault Codes
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 6L0 035 156 B
Component: seat s04 GRO 4100
Coding: 00401
Shop #: WSC 06402
VCID: 285A6424C8E83A9
No fault code found.
End ---------------------------------------------------------------------
Coding: 00031
Shop #: WSC 06402
3 Faults Found:
Coding: 24589
Shop #: WSC 06402
3 Faults Found:
37-00 - Faulty
Coding: 00014
Shop #: WSC 06402
3 Faults Found:
37-00 - Faulty
Coding: 00065
Shop #: WSC 06402
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 00401
Shop #: WSC 06402
Titling a thread "hundreds of fault codes" is a good way to put anybody off.
The common factor seems to be a lack of communication between modules - "Databus Wiring and/or Connector(s) faulty". I think your databus is fried - either the wiring or the interfaces in the modules.
You seem to have some modules which do not communicate at all, starting with the instrument cluster and its (internal) gateway. Unless you get that sorted you won't get far. So check all fuses and the wiring / power supply in general. Also check if the cluster operates at all, i.e. which check lamps (ABS, Airbag) are active and working.
Got this fixed in the end by having the ABS ECU and the normal ECU, clocks and so on replaced! Seems that the lighting just fried the lot!
Ben
