For sure not! You can pick up decent ones for maybe 350 quid front and rearI’m now thinking save some cash up and have a road trip don’t think they will notice difference in seats on the way back
its hard here in NL.For sure not! You can pick up decent ones for maybe 350 quid front and rear
its hard here in NL.![]()
first i wanted to swap everything from my topsport. those seats are in great condition. havent seen any similar for sell. or way over 500 euro
The rubber/plastic pipe from the caliper to the copper/steel brake pipesFlexi as in brake line?
i can get some cupra wheel on local site here. 18 inch, 7,5Jlink? F**k why am I just seeing this
fitted the brakes today, and i had the same issue, drilled it out a little. ^^Yes the Flexi brake line the black part where the brake pipe from the car joins onto the the brake line from the brembo the metal tab inside the inner wheel arch was different on mine so had to file some metal away to get it to fit and use the slide clip to hold it in place
That means you have your stock 288mm? Discs and calipers?fitted the brakes today, and i had the same issue, drilled it out a little. ^^
I meant are you selling your brakes nowno, the whole in the bracket that connects the brakeline to the metal piping, the niple of the brembo line is like a mm larger diameter to fit through.
Thats what i thought u ment lolI meant are you selling your brakes now![]()
only the callipers, will fit the discs and pads on the topsport since their new. arent they 312mm ?I meant are you selling your brakes now![]()
I thought they were 288 but measure would be best! I can measure tomorrowonly the callipers, will fit the discs and pads on the topsport since their new. arent they 312mm ?
na they are the same as my topsport. 312 mmI thought they were 288 but measure would be best! I can measure tomorrow
Cool good to know, **** then they aren't much smaller than the RS 326mm the 312 are also what the S3 uses. I think only the Cupra R has 326 with brembosna they are the same as my topsport. 312 mm
