Hi Guys, I'm new to this so. I have got a Seat
leon mk1 2002 1,9tdi which is having funny problems.
On turning the key to the 2nd position, there is a noise that is normal and i can only assume its the fuel pump, or automatic primer or something of this nature. This noise used to go away after a few seconds but its not stopping now. I have located whatever is making the noise to be underneath the wiper fender on the drivers side.
When i start the car after about 1 second the car cuts off with a traction light on constant, and a flashing oil light, there is not immobilizer light on to suggest the key is at fault.
I have however recently changed the ECU on the car, and changed the ignition barrel and the clocks so im not sure if this is the
problem or if the
problem could be a faulty fuel pump or engine speed sensor.
The car has been lying for about 12 months after if had a head gasket changed so its also a possibility that the timing may be off.
Where is the best place to start, it seems very much so that it is an electrical
problem as i'd imagine if it was a pump the car would at least use the fuel in the filter.
Any
help would be great, i'm coming to the end of the road and don't know where to go from here.
