bertiebucket
I have a Seat Leon problems as my kids have pressed some buttons and now the radio is locked.
The display reads:
2 SAFE
And it doesn´t let me put in the radio activation code.
Any ideas where I am going wrong PLUS the number buttons only go from 1 to 6 but my code number includes a ZERO and a NINE which I don´t have a clue how to input.
Help please
Thanks to you all
You will have a 4 digit code.To inpout the 1sdt digit you press the no. 1 button as many times to come to the relevant number,for the 2nd digit press the no. 2 button till you get to the required no. and then the same with buttons 3 and 4 for the 3rd and 4th digit.
Probably not explained very clearly but i hope it makes sense!!
To get it off the '2 safe' message you need to leave the car with the electrics turned on for something stupid like an hour :\
tx psymonkee
Just a question on your reply, when I leave the electrics on do I leave the radio on or off?
When mine went had to leave the igntion on for an hour with the radio on.
don't worry about leaving ignition on, cause you'll have to sit with it for at least an hour! had to do same thing with my hu, just switch it on and then lock up and leave it. about an hour later you should be able to input the code.
I did one better than that
I cleaned my car whilst I waited :D
