Did the translate in google so hope its okay.
Start to keep down the trip meter, then re-ignition of the car. Release the odometer stick and turn it once to the right. Then service interval would be reset
Remember that you must first put the key in the ignition when you put the ignition on. In other words, the key must not be in when you hold the odometer does stick
Yeah, that's something like it.
  • Key in the ignition but not turned on.
  • Press and hold the reset knob on the left hand side of the dash display (with your left hand).
  • Then turn the ignition on with your right hand.
  • Then turn the reset knob to the right.
Sorted.
