__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Ok,
So by this afternoon i should have my WMI all installed, i have a good idea of what it exactly does and why i have installed it but i was wondering if sombody in the know could give me a a quick idea of what logs i should be doing and what should be adjusted on the controler and when?
I`ve read that it should start spraying approx 1/4 of your full boost and around 3/4 of your full boost, if thats the case how come they didnt just put one setting on it? So my question is, when would i need to adjust these settings, what kind of behavioir should i be looking for while twiddling the knob?
I understand that i can adjust the timing looking at block 020 but what other blocks should i be logging and what blocks together?
I dont have a AFR gauge at the moment :( (on order from this afternoon)so im hoping all this isnt a pointless post.
Thanks.
Any one :(
All ready to go now just need to fill the tank up!
Wheres DPJ when you need him!
Well its all in and working now, that stuff doesnt last very long does it!
Seems to have made a slight difference already without any tweeks made, very happy with it so far but could still do with abit of help on what to log and using the controller to fine tune the spray.
Please :(
What size nozzle are you using?
If it starts spraying too low down the rev range, you may find it quenches your combustion. Aim for max delivery by the time you hit max boost (assuming a boost sensing kit)
Start with a low mix - ie 25% methanol.
Log your intake temperatures to see what difference it makes.
Once you're satisfied there, try logging 020 CFs (along with another block that shows revs like 003 - good because it shows timing too)
If you have no CFs, try advancing the timing a bit using Unisettings/Lemmiwinks - and log CFs again.
If all is well, increase the % mix to 33% - then 40% - then maybe 50%.
Be aware it's really hard to tell if you are using too much methanol until on the rollers. Don't go to high volumes / % until you've seen a RR run you are happy with.
-If you're only using it to cool intake temps (and not increasing timing), use the lowest % mix you can get away with (based on logging intake temps)
Cheers Dave, some great info there!
I`m currently using a DO4 nozzle as its what came with the kit i bought (2nd hand) Bill has said it "should" be ok as it came off a stg2 LCR which is basicly what im running in the Ibiza, How will i know if i need to change down?
I actully used some 50/50 mix yesterday that Nick had left over when i bought his kit, but that went pretty quickly!
I`ll now do what you said this evening and get some logs up.
When you say quenches your combustion, do you mean basicly throwing to much in and make the car buck? If so i had that last night when i planted it in second, at the moment i have it to start spraying at 6 and hit full at 15 - currently my boost is spiking at 25psi.
Im going to be booking her in with Bill to get it properly tweeked, but i`d just like to understand and maybe tweek abit myself before it goes to Bills, as that would be at least 2 weeks away and thats if he`s able to fit me in then.
Sorry read your last post totally wrong :doh:
Here you go,
Code:
Sunday	26	July	2009	19:55:23
6K0 906 032 AA 		1.8L 20VT EU3    01 0002
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
MARKER	STAMP	 /min	%	 mbar	 mbar
	0.01	1400	75.9	1690	1110
	0.36	1440	78.2	1720	1130
	0.76	1480	79.7	1740	1150
	1.16	1520	83.5	1750	1170
	1.56	1600	85	1750	1190
	1.96	1640	85	1750	1210
	2.36	1680	85.7	1750	1230
	2.76	1720	88	1750	1250
	3.16	1800	91	1750	1270
	3.56	1840	94	1760	1290
	3.96	1880	94.7	1780	1310
	4.36	1920	99.2	1790	1340
	4.76	2000	103.8	1800	1370
	5.16	2040	107.5	1830	1400
	5.56	2120	109.8	1840	1440
	5.96	2200	115	1850	1490
	6.45	2280	122.6	1880	1560
	6.85	2360	135.3	1910	1640
	7.25	2400	144.4	1940	1730
	7.75	2520	156.4	1990	1880
	8.15	2600	163.9	2020	1990
	8.66	2720	170.7	2080	2140
	9.06	2800	178.2	2110	2240
	9.46	2960	186.5	2140	2350
	9.86	3040	191.7	2140	2430
	10.26	3160	191.7	2170	2480
	10.66	3280	191.7	2180	2450
	11.06	3360	191.7	2200	2380
	11.44	3480	187.2	2230	2340
	11.84	3600	181.2	2250	2310
	12.24	3680	180.5	2270	2300
	12.66	3800	182	2280	2280
	13.06	3880	178.9	2280	2270
	13.44	3960	182.7	2290	2250
	13.86	4120	181.2	2280	2290
	14.24	4200	182.7	2280	2300
	14.66	4280	179.7	2280	2300
	15.15	4400	180.5	2270	2290
	15.55	4520	183.5	2270	2300
	15.95	4600	187.2	2250	2310
	16.35	4680	188.7	2250	2280
	16.87	4800	191.7	2240	2280
	17.27	4880	191.7	2240	2270
	17.67	4960	191.7	2230	2250
	18.07	5040	190.2	2240	2260
	18.47	5120	191.7	2260	2260
	18.85	5240	190.2	2270	2270
	19.25	5280	190.2	2260	2260
	19.65	5320	188	2270	2250
	20.05	5400	186.5	2280	2270
	20.45	5440	186.5	2290	2250
	20.85	5520	184.2	2310	2270
	21.25	5560	185	2320	2260
	21.65	5640	185.7	2330	2280
	22.05	5680	185	2350	2290
	22.45	5720	186.5	2340	2290
	22.85	5720	186.5	2350	2300
	23.25	5800	185.7	2360	2310
	23.65	5840	185.7	2360	2320
	24.05	5880	185	2350	2330
	24.45	5920	185.7	2350	2320
	24.85	5960	184.2	2350	2320
	25.25	5960	184.2	2340	2330
	25.65	6000	184.2	2330	2310
	26.16	6040	182	2320	2330
	26.56	6040	183.5	2330	2320
	27.06	6040	181.2	2320	2320
	27.46	6120	182.7	2330	2340
	27.86	6120	179.7	2330	2340
	28.26	6800	28.6	990	2220
	28.66	5120	121.8	2260	1320
Do you not need to adjust the fuelling in unisettings when using the methanol?
Interesting you mention the D04 nozzle is too big as I think my kit came with a D05, bills going to weld a boss on to ally coupler and then send that and the nozzles to me (rest of the kit has been fitted and wired in)
I'm have an LCR with hybrid K04
Cheers Dave, I`ll be on the case with some logs tonight and report back!
I belive fuel is to be adjusted, if so either i`ll do it when i get my AFR gauge or when it goes down to Bill which ever comes first.
I had one of Bills boss`s welded on yesterday works a treat. :thumbup:
No, not normally. You'd adjust timing. I wouldn't want to do anything to make a car run leaner without very accurate reliable data to back the adjusments up.....
Meaning a wideband AFR setup?
Would not reducing fuel and chucking methanol in casue it to run slightly rich?
So its meant to be richer? , I understand stotic is for best acceleration but only How would i go about reading that figure? AFR gauge?
Sorry i must sound such a n00b, well i am to this :D
Do you run a AFR gauge Dave?
What kind of AFR readings would i be looking for once i have my gauge installed and running the meth?
