Share your revo SPS Setting
Invincible
226
Dubai
Hey,
Let's all share our Revo SPS setting with other mods on the car and a bit of a review on how the car feels would be perfect.
Mine is as follows:
Revo Stage 1
Boost 7
Timing 4
Fuel 9
Mods on the car:
BCS Cat-back Exhaust
Evom V-flow Intake
Car pull is very quick for a Stage 1, kept up with a Revo Stage 2 Golf R, there's a huge surge of power just after 2.5k RPM and it goes all the way up to 5 where the power drops slightly.
Fuel Consumption is not great though, car runs a little rich.
What's everyone else on?
Marshall
3,256
Bonnie Scotland
When I had my last car on Revo it was
Boost 7
Timing 5
Fuel 9
After lots of logging I found those the best on stage 1
On stage 2
Boost 8
Timing 5
Fuel 9
Since changed car and running APR software with no adjustment necessary or available.
Invincible
226
Dubai
Boost 7
Timing 5
Fuel 9
On stage 2
Boost 8
Timing 5
Fuel 9
Hmm, what kind of fuel did you run with that? and how was the weather outside. im planning to do some logging today to see what its like to increase my timing by 1, so I'll be running 7-5-9, will probably need to drop that back to 4 when summer comes as temps could reach up to 50c degrees in dubai!
i ran 6-4-9 for the past 2 days, no issues during data logging, but it didnt feel as fast as 7-4-9 although the power delivery was more linear.
Will be working on 6-5-9 and 7-5-9 today to see how it feels
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
Revo new stage 1 map.
Cold weather:
Boost - 9
Timing - 6
Fuel - 9
When it warms up again i run:
Boost - 8
Timing - 5
Fuel - 9
Always fill up with Tesco Momentum 99 and get good timing correction values e.g under 3 on high load.
I find with Momentum 99 I can run 1 timing higher than vPower and get good timing figures.
When I was on vPower max timing was 5 in the cold and then it was close to pulling too much timing after it was running hard for a bit.
All standard kit apart from stage 1 revo map
Invincible
226
Dubai
Cold weather:
Boost - 9
Timing - 6
Fuel - 9
Boost - 8
Timing - 5
Fuel - 9
wow, what peak boost would that result in? Unfortunately we can't pull such figures in my region due to extrmely hot weather, and fuel is only 98 RON
Al
7,199
9
Stage 2+
Boost 9
Timing 5 (can do 6 If I want to)
Fuel 5
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
hey, what kind of fuel are you rinning to have timing at 6? do you have an IC either?
do you also remember what was the fuel setting with this as well?
BEEFYGTI's is a mk1 mate, we can't adjust the fuel setting.
Mine runs best at:
Boost - 8
Timing - 8
Alway's run Shell VPower
Bignod00
2,170
Lincoln/40,000 ft.
Stage 2+
Boost 9
Fuel 5
Same settings for me too @ Stage 2+
However during the winter always running with Boost on 7 as it is much easier to out the power down. Feels slower on the 'bumdyno' but in real world conditions works much better!:D
RobH
1,546
West Yorkshire
Boost 7/8 Timing 6 fuel 6
Stage 2+ with all the mods
Hate how the car feels on boost 9 and the above settings made more power and for longer. Cant remember if its boost 7 or 8.
JayCee
236
Isle of Man
6, 5 and 6 at the mo' (from memory), but had it dyno'ed at 9, 6, 7
Dropped it back to 6 on boost as weather is to cold/wet for anything else really!
