Shock Horror :(
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
Went to have a new tyre put on my beefa and found the back tyre almost bold!!! couldnt believe it, you cant check it easily as my cars soo low lol hadnt noticed, bit p*ssed off with the tyre com[any not warning me as they fitted a new one about a month ago. Off the road for a few days :(
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
That will be because your car has been lowered and the castor/camber not being changed. Needs 4-way aligning and setting up correctly. Dunno if you can get castor/camber adjuster kits for these. Does anyone know. Did it run the inner edge of the tyre off?
markupra
Newbie
Sep 4, 2006
54
you can't adjust the rears as far as I know. I just got the front camber and tracking done
markupra
Newbie
Sep 4, 2006
54
yeah theres quite a bit of adjustment in it. I took mine to a garage that does rally cars, they had a portable machine to do camber and tracking. they adjusted the settings to as close to standard as they could get, seems ok and handles much better. It might be a plan to raise it a bit if its really low.
Oct 17, 2006
893
Walthamstow
had simular issue - i had a flat on passenger rear and i didnt notice any change in driving - its only when i turned a corner i heard it - but i had 2 massive rips on the inside - each one was about 12inches long - close shave
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
ive had all the balancing done properly all wheels are now 0,0 bearing in mind i have coilovers not standard suspension, but 2x tyres 195/45/r16 £30 off a mate bargain :)
