I was goina fit that but decided against it and went for neuspeed short shift, same as TT but with shorter throw, works a treat.
someone has definately fitted one... u need to get a "lift reverse" gearknob tho
i think they look like a good piece of kit... much cheaper now than they used to be too!
guess it depends if u want to keep a standard gearknob
The miss`s is getting me one for my birthday (2 weeks) so ill let you know how i get on with it.
I just emailed the seller asking if its a push down or lift up reverse once installed. I think some of them you are able to keep the OEM knob.
This is the response i got,
Hi
Not actually sure but would assume it will work as normal (push down) no reason to think otherwise.
U-zera
Think im just gunna wait until i have it to see what knob to get.
i found a set of fitting instructions on line a while ago and im pretty sure u have to use a lift reverse knob... il have a quick look now
I`d like to keep the OEM knob to as some of those aftermarket seat sport knobs are pretty tasty. expensive, but tasty ;)
Hasnt PhilW got this? He will know if it can be push down reverse or point us in the direction of which his kit is if its push down reverse. His is an ebay B&M copy I believe.
I think i might just get the Neuspeed one as i know it works well and is relatively easy to fit.
The only problem with the ebay one is i'm guessing you'll have to take off the exhaust and drop the selector out to fit it.
Yeh the exhaust has to come down along with the heatshield which apprently can be a pain.
