should i lower my car?
ibiza_cupra_gti
61
hi all thinking of lowering my car 60m on the front and 40m on the back its currently on 17s but looks abit high..what u think?
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
dropped 40 front and back on eibach springs, lowered perfectly but was a little crashy over bumpy surfaces. the first pic was shortly after having them fitted, the second was a month or so later after they had been run in.
ibiza_cupra_gti
61
i want to lower it for the looks mainly..i was thinkin of buying a full spring and shock kit off ebay i think its made by fk,i wanted to lower it more on the front because its alot higher than the back.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
unless you get rear adjustables the rears when on an equal front/rear drop will look higher due to less weight on the rear, once you are in the car it should look fine.
justinking
136
i have a set of mk2 coilovers for sale mate, got them in the group buy but had a change of mind.. couple of pics..
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Get a set of FK Highsport Coilovers (like above), adjust the height to whatever you like then and they are real good!
Dave_R
Sep 20, 2004
3,666
South Wales
Not really sure, i think it's but 60-65mm. I just left the coilovers how they were when I took them out of the box and raised the front end a lil bit the other month but best thing wiv coilovers is that if you want it lower 10mins work and it's done.
