basically wanted the same cubby hole as i had in my mk4 golf, and i 4t some of the leons come with sat nav and im guessing that would be a double din unit, i just need some decent pictures of the types of dash, in theory im guessing it would be a new centre console, eg were the hazard and cup holder is and also the heater switchs and a new cage.......
hi.
yes its poss..
pabs has done it.. goto members at top of page. click on p and go down till you find pabs("chill dude") and click on his name. then click his home web page.....new page should open...
click on guides..new page should open...scroll down till you find double din dash.
comes with pics and explanation.
hope this helps
he is good aint he... done abit on my car from his site...w8 light(looks cool at night), rear wiper this is a must mod on ya car and takes 5mins to do
if you need the part no give us shout..all in less than £20
NOW BACK TO YOUR Q'S
not to sure to be honest... maybe if the wiring loom is there for it. could try a search on here.
THIS SITE IS FULL OF INFO..
You need more than the display to convert to climate I'm afraid. But you might find your manual dials fit in OK, it the control panel is the same size as the climate display unit.
gotta say people on here really helpful, yea please could i have the part numbers il get that done asap, as the standerd one does luk abit old and dull
ive put a tread up for the climate and its guna b alot hassle by the looks of it
but as Toms said possibly a audi mk1 centre console mite go straight in! so im gunna check into that 2mr at some point thanks so far every1
i see what you mean if the matrix is the same size RobM, but my matrix is built in to the surround.... its a 51 plate leon, dont know if there was a slight facelife along the way..
jay87..
if you do a search under "upto date" it should show you a thread from me.
showing part no:s and prices.
it very easy to do. remove cover where the water jets out,don't worry if it breaks you have a new one. undo nut 13mm spanner i think...may need wd40 to make it easier..then pull it up..may need a wiggle or two..fit new one in reverse.
there is a guide for this i think pabs did it..
but one thing to say is that your new wiper hole that fits on the wiper spindle is diff from old wiper...old one has teeth...get you wiper in correct postion then tighten up the nut...still works well and NO JUDDER
