Single or double headlight?
gouldy88
Hi, this is the headlight on my 13 plate FR, is it a single or double? I ask because when sidelights are on i only see 1 bulb light up, the one on the right.
h tt p://i58.tinypic.com/15z5eo9.jpg
Feb 8, 2011
743
I'm assuming it is a UK spec. My car is pre-facelift and works like this.
Should be a twin bulb headlamp unit which has two small sidelamp bulbs and 2 large headlamp bulbs. One unit on each side of the car.
Switch position 1. Just the two small sidelamp bulbs on each side of the car.
Switch position 2 and dipswitch forward. Two small sidelamp bulbs and one (dipped) bulb.
Switch positon 2 and dipswitch back. Two small sidelamp bulbs, one dipped bulb and one main beam bulb.
DEAN0
Old Git
Feb 1, 2006
5,439
Preston - UK
So others can see it - here is your link - http://i58.tinypic.com/15z5eo9.jpg
Yes that is double headlamp.
You have the dip beam and a sidelight on in the pic.
The other bulb that is not on is the main beam.
gouldy88
Yeah I have dipped beam on in the pic, so if I were buying some new sidelight bulbs would I need 2 bulbs or 4?
Feb 8, 2011
743
My pre-facelift double headlamps have two sidelamp bulbs in each lamp unit as I explained above.
Feb 8, 2011
743
Ah! - even more cost cutting. I rather like two; it's a backup. I believe I have two each side at the back as well.
